Clicknow Posted June 30, 2019 Share Posted June 30, 2019 Hi I want to add a LED brake light to my top box which has 2 wires,one red and one black,having looked at the wireing on my GT it has 3 wires one blue,one yellow and one black,and iam not sure which 2 I should wire into? Has anyone any experience with this? Many thanks graham Link to comment Share on other sites More sharing options...
wordsmith Posted June 30, 2019 Share Posted June 30, 2019 The brake light wire is yellow. I'll be doing the same shortly... Riding a fully-farkled 2019 MT-09 Tracer 900 GT from my bayside home in South East Queensland, Australia. Link to comment Share on other sites More sharing options...
Clicknow Posted June 30, 2019 Author Share Posted June 30, 2019 Thank you so I should wire my red top box wire to the yellow GT wire and the black top box wire to the black GT wire? thanks again Link to comment Share on other sites More sharing options...
Clicknow Posted June 30, 2019 Author Share Posted June 30, 2019 Would you say this is correct? As don't want to blow any fuses! Regards Graham Link to comment Share on other sites More sharing options...
wordsmith Posted June 30, 2019 Share Posted June 30, 2019 8 hours ago, Clicknow said: Would you say this is correct? As don't want to blow any fuses! Regards Graham If in doubt - as you clearly are - why not check with your local dealer? Riding a fully-farkled 2019 MT-09 Tracer 900 GT from my bayside home in South East Queensland, Australia. Link to comment Share on other sites More sharing options...
Clicknow Posted June 30, 2019 Author Share Posted June 30, 2019 I may do that,but thought I would try here first,someone may of done the same thing. regards Link to comment Share on other sites More sharing options...
skipperT Posted July 1, 2019 Share Posted July 1, 2019 Yes that’s correct. You won’t blow any fuses unless you touch the yellow or blue wire to metal, or to the black wire. Besides it’s better to blow a fuse than witness a wiring harness going up in smoke because it wasn’t fused... -Skip Link to comment Share on other sites More sharing options...
ruenjou Posted July 1, 2019 Share Posted July 1, 2019 Yea yellow to red and black to black Link to comment Share on other sites More sharing options...
skipperT Posted July 1, 2019 Share Posted July 1, 2019 Lovely diagram there, Ruenjou, however without showing which switch operates the brown and yellow wires, your pic needs further explanation for how you came to the conclusion that you did... -Skip Link to comment Share on other sites More sharing options...
Clicknow Posted July 1, 2019 Author Share Posted July 1, 2019 Hi thanks all,its all complete now and looks and works well all the above info is correct. Regards Graham Link to comment Share on other sites More sharing options...
ruenjou Posted July 1, 2019 Share Posted July 1, 2019 33 minutes ago, skipperT said: Lovely diagram there, Ruenjou, however without showing which switch operates the brown and yellow wires, your pic needs further explanation for how you came to the conclusion that you did... -Skip Haha. 95 is the tail light connector. Yellow wire goes to the rear brake switch while brown wire goes to ignition switch. Black is ground... Link to comment Share on other sites More sharing options...
