budviking Posted March 6, 2018 Share Posted March 6, 2018 I'll be soon moving into a townhouse with a garage and have considered getting a lift for working on the bike and better access for cleaning down low. Most of the ones I've seen appear to rely on the bike having a flat engine to rest on and carry the weight, but the underside of the FJ is all exhaust system. Anyone using a lift that will allow the wheels to come completely off the ground, and if so what type? Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted March 6, 2018 Supporting Member Share Posted March 6, 2018 This stand offers maintenance access from every possible angle. Abba Skylift ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted March 6, 2018 Supporting Member Share Posted March 6, 2018 Most of the ones I've seen appear to rely on the bike having a flat engine to rest on and carry the weight, but the underside of the FJ is all exhaust system.Since the bike has a center stand, you are half way there. I have always used a floor jack under the headers to raise the front end for wheel or suspension removal. I just use a folded towel on the jack lift to avoid scratching the exhaust. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
koth442 Posted March 6, 2018 Share Posted March 6, 2018 I have the harbor freight special. It works. It holds the bike. Its a bit wobbly while your jacking up the bike for sure, but once its its up, its fine. Also I got rid of their stupid wheel chock. No way I'm using that thing. The FJ goes on the center stand. If I'm really beating on her, tie downs to the U bolts. The GSXR goes on a rear stand. https://www.harborfreight.com/1000-lb-steel-motorcycle-lift-68892.html I got it for ~$300. Well worth the money. Would buy again. It *IS* heavy though. So getting it home might be a PITA. '15 FJ09 Link to comment Share on other sites More sharing options...
Scooter426 Posted March 6, 2018 Share Posted March 6, 2018 Got these stands off Amazon. The pins do fit the headset. Pretty stable. I did put spools on the swingarm too. Perfect setup for doing tire changes. The other front stand that Venom makes (cradle type) does not work on the front forks due to ABS sensor. Front Stand: https://www.amazon.com/Venom-Motorcycle-Triple-Headlift-Yamaha/dp/B01N0GSV96/ref=pd_sbs_263_5?_encoding=UTF8&pd_rd_i=B01N0GSV96&pd_rd_r=DEFAMQFP478GVV3TSQEM&pd_rd_w=W0Qds&pd_rd_wg=nOcLi&psc=1&refRID=DEFAMQFP478GVV3TSQEM Rear Stand: https://www.amazon.com/Venom-Motorcycle-Swingarm-Paddock-Kawasaki/dp/B0036QX4EY/ref=pd_sbs_263_6?_encoding=UTF8&pd_rd_i=B0036QX4EY&pd_rd_r=DEFAMQFP478GVV3TSQEM&pd_rd_w=W0Qds&pd_rd_wg=nOcLi&psc=1&refRID=DEFAMQFP478GVV3TSQEM Link to comment Share on other sites More sharing options...
Scooter426 Posted March 6, 2018 Share Posted March 6, 2018 Here are the swingarm spools I bought on Amazon: https://www.amazon.com/gp/product/B00Y44HVKK/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1 Link to comment Share on other sites More sharing options...
Scooter426 Posted March 7, 2018 Share Posted March 7, 2018 I did end up putting boards on the ground to get a bit more lift. Only needed about 1”, as I remember. This is an issue for many of my bikes with this type of stand. I do not see it as an issue, really. I used two small scrap boards of 1x8. It gives it just enough lift to do front wheel removal. Link to comment Share on other sites More sharing options...
budviking Posted March 8, 2018 Author Share Posted March 8, 2018 Quote Betomy: "This stand offers maintenance access from every possible angle. Abba Skylift" I looked at the video for this lift on the vendor's site. It looks like it relies on a pivot pin fitting into the swing arm pivot, which is not exposed on the FJ. Will this work? Do you use one yourself? Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted March 8, 2018 Supporting Member Share Posted March 8, 2018 Quote Betomy: "This stand offers maintenance access from every possible angle. Abba Skylift" I looked at the video for this lift on the vendor's site. It looks like it relies on a pivot pin fitting into the swing arm pivot, which is not exposed on the FJ. Will this work? Do you use one yourself? I have not used this lift stand. Looking at their website, they sell bike-specific adapter kits. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
3banger Posted March 9, 2018 Share Posted March 9, 2018 The FJ swing arm piviot is the big bolt on the rear set mount. So the adapter is a cup that goes over the bolt. On the other side the adapter is a truncated cyclinder that plugs into the same spot. I’m seriously considering this as a work stand. Between the girlfriend and my self we’ve got five bikes and I,ve always got one on paddock stands for some reason or another. I very much enjoy wrenching on bikes but I’m really tired of always sitting the floor. Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted March 11, 2018 Premium Member Share Posted March 11, 2018 I have used solely Pit Bull F&R stands for 27 years but bought on close-out a third set of stands for $35 for the pair (!) that are stable enough for casual use. I've also have a Handy Industries MC air lift with the wheel vice I bought in 95 when I built my shop. The latter have doubled in price and then some, and so have PB and Woodcraft stands... But then again I also have a No Mar tire changer and balancer and 20 feet of work bench, machining equipment, welders, etc in my heated and air conditioned carpeted shop that requires you wear sunglasses when all the lights are on Link to comment Share on other sites More sharing options...
Premium Member Trambo Posted March 11, 2018 Premium Member Share Posted March 11, 2018 I have used solely Pit Bull F&R stands for 27 years but bought on close-out a third set of stands for $35 for the pair (!) that are stable enough for casual use. I've also have a Handy Industries MC air lift with the wheel vice I bought in 95 when I built my shop. The latter have doubled in price and then some, and so have PB and Woodcraft stands... But then again I also have a No Mar tire changer and balancer and 20 feet of work bench, machining equipment, welders, etc in my heated and air conditioned carpeted shop that requires you wear sunglasses when all the lights are on I... hate you. Wait. I love you. And hate you. 2015 Stealth Grey FJ-09 Pilot Base of Operations: Chesterfield, VA Farkels? Lots, nothing flashy, but all functional... Link to comment Share on other sites More sharing options...
koth442 Posted March 11, 2018 Share Posted March 11, 2018 I have used solely Pit Bull F&R stands for 27 years but bought on close-out a third set of stands for $35 for the pair (!) that are stable enough for casual use. I've also have a Handy Industries MC air lift with the wheel vice I bought in 95 when I built my shop. The latter have doubled in price and then some, and so have PB and Woodcraft stands... But then again I also have a No Mar tire changer and balancer and 20 feet of work bench, machining equipment, welders, etc in my heated and air conditioned carpeted shop that requires you wear sunglasses when all the lights are on Pit Bull makes great stuff, can't go wrong there! Are you a hobby machinist? '15 FJ09 Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted March 11, 2018 Premium Member Share Posted March 11, 2018 I am a semi-retired engineer and fabricator that started out in aerospace in the 70s then plant layout and design which led to building failure consulting after that, all the while operating my little shop geared toward advanced composite structural and aero components for ultralights and motorcycles... Link to comment Share on other sites More sharing options...
koth442 Posted March 11, 2018 Share Posted March 11, 2018 Very neat! I'm sure we could chat quite a bit about all of that. BUT probably best not to de-rail the thread too extensively. '15 FJ09 Link to comment Share on other sites More sharing options...
