Premium Member clint Posted January 2, 2017 Premium Member Share Posted January 2, 2017 Anyone install Speed Bleeders yet on their FJ-09? I'm having a hard time finding the proper sizes. Piedmont of NC '15 FJ-09 '94 GTS-1000 Link to comment Share on other sites More sharing options...
Premium Member wessie Posted January 2, 2017 Premium Member Share Posted January 2, 2017 get a Mityvac http://mityvac.com/pages/products_bcbe.asp This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
Premium Member clint Posted January 3, 2017 Author Premium Member Share Posted January 3, 2017 get a Mityvac http://mityvac.com/pages/products_bcbe.asp I've seen Mityvacs draw air from around the bleeder threads before. I've had more success with SpeedBleeders and a catch bottle. Piedmont of NC '15 FJ-09 '94 GTS-1000 Link to comment Share on other sites More sharing options...
Premium Member wessie Posted January 3, 2017 Premium Member Share Posted January 3, 2017 get a Mityvac http://mityvac.com/pages/products_bcbe.asp I've seen Mityvacs draw air from around the bleeder threads before. I've had more success with SpeedBleeders and a catch bottle. Not heard anyone diss a Mityvac - used extensively in race paddocks in the UK and highly regarded by those with Tokico 6 pot calipers who have to rebuild them every spring until they discover Nissin 4 pots are a direct swap. This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
Premium Member clint Posted January 3, 2017 Author Premium Member Share Posted January 3, 2017 ....I've had more success with SpeedBleeders .......the countless times i had to bleed brakes on vehicles, and I just discovered this...why? News travels slowly in the Great White North. Piedmont of NC '15 FJ-09 '94 GTS-1000 Link to comment Share on other sites More sharing options...
jsp Posted January 3, 2017 Share Posted January 3, 2017 get a Mityvac http://mityvac.com/pages/products_bcbe.asp I've seen Mityvacs draw air from around the bleeder threads before. I've had more success with SpeedBleeders and a catch bottle.I use the MityVac with a trick. Remove the bleeder and put 2 turns of Teflon tape on the threads. Reinstall the bleeders. No more bubbles. john Link to comment Share on other sites More sharing options...
Premium Member clint Posted January 3, 2017 Author Premium Member Share Posted January 3, 2017 News travels slowly in the Great White North. ...ah, family!!...take off, eh? The bleeders look like an awesome product... any idea how well they'd do in automobiles in harsh conditions (annual bath in salt brine, freezing-thawing etc.)? They come in Stainless Steel for a bit more $$. Those should hold up well in those conditions. Piedmont of NC '15 FJ-09 '94 GTS-1000 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted January 3, 2017 Supporting Member Share Posted January 3, 2017 I have always used a Motion Pro Bleeder - Same basic principal for bleeding. Very simple and effective. To make things even easier, I installed a master cylinder off an R1 on the front, it has the bleed port right near where it connects to the handlebar, the highest point in the system. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted January 3, 2017 Supporting Member Share Posted January 3, 2017 I have always used a Motion Pro Bleeder - Same basic principal for bleeding. Very simple and effective. To make things even easier, I installed a master cylinder off an R1 on the front, it has the bleed port right near where it connects to the handlebar, the highest point in the system. ...that would be in addition to bleeding at the calipers, I assume? That's where the fluid degrades, and boils... thus water/air in the lines... no?When I do a complete system flush, I use the Motion Pro bleeder at each caliper to get the fluid down to the caliper, I use the bleeder at the master cylinder to get the last of the air. I usually crack the port open 1/4 turn, pump the lever 2-3 times and it is finished. If you cant find the correct size speed bleeders, the Motion Pro tool works the same and makes the job so easy. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
desertfjr Posted January 3, 2017 Share Posted January 3, 2017 I live in the Great White North...the brake fluid gets purged every winter...Speed Bleeders went in immediately. Makes the job go quite fast. Link to comment Share on other sites More sharing options...
eeetea Posted January 3, 2017 Share Posted January 3, 2017 I just use a syringe and some tube. Never had a problem tbh. Honda SS50, Kawasaki Z200, Honda 400/4, Yamaha TDM900, Yamaha XT660Z Tenere, KTM 990 Adventure, BMW R1200GS, Mr Stevens, and my favourite of all: Yamaha MT-09 Tracer...a bit like FJ-09 only properly named :¬P Link to comment Share on other sites More sharing options...
Premium Member clint Posted January 3, 2017 Author Premium Member Share Posted January 3, 2017 I live in the Great White North...the brake fluid gets purged every winter...Speed Bleeders went in immediately. Makes the job go quite fast.@desertfjr, which Speed Bleeder did you install? SB8125L on all three calipers? Piedmont of NC '15 FJ-09 '94 GTS-1000 Link to comment Share on other sites More sharing options...
Premium Member wessie Posted January 3, 2017 Premium Member Share Posted January 3, 2017 I just use a syringe and some tube. Never had a problem tbh. Is this for artificial insemination or rectal narcotics? This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
desertfjr Posted January 4, 2017 Share Posted January 4, 2017 SB8125L front and rear. I went with stainless units. Link to comment Share on other sites More sharing options...
snowflake Posted January 12, 2017 Share Posted January 12, 2017 I installed the Speed bleeders on my FJR last fall. Five of them! They work great. The FJ-09 will get them this summer when the service is due. Link to comment Share on other sites More sharing options...
