Dark&Stormy Posted October 12, 2016 Share Posted October 12, 2016 HI I was wondering if anyone knew of a way to clear diagnostic codes? Can it be done without a dealer tool? Or will the codes go away on their own once there is no longer a fault? Link to comment Share on other sites More sharing options...
bruceintucson Posted October 13, 2016 Share Posted October 13, 2016 HI I was wondering if anyone knew of a way to clear diagnostic codes? Can it be done without a dealer tool? Or will the codes go away on their own once there is no longer a fault?What are the code #'s? Some will clear themselves, some can clear once the problem is corrected (69 code is problem with ABS front wheel sensor), and some need the "Gameboy" at the Dealer. Why are you getting codes BTW? Link to comment Share on other sites More sharing options...
Dark&Stormy Posted October 13, 2016 Author Share Posted October 13, 2016 i tried installing a speed correction device and it gave me the 069 front speed sensor fault. If I disconnect the device and close the loop the code still remains. Link to comment Share on other sites More sharing options...
GoldenPenguin Posted October 13, 2016 Share Posted October 13, 2016 i tried installing a speed correction device and it gave me the 069 front speed sensor fault. If I disconnect the device and close the loop the code still remains. Have you tried riding around a bit with that code on after unplugging the device? It should clear itself automatically. Link to comment Share on other sites More sharing options...
Dark&Stormy Posted October 13, 2016 Author Share Posted October 13, 2016 i tried installing a speed correction device and it gave me the 069 front speed sensor fault. If I disconnect the device and close the loop the code still remains. Have you tried riding around a bit with that code on after unplugging the device? It should clear itself automatically. That's what I thought would happen also, but both the ABS and CEL stay on and then after riding for about a minute the TCS light illuminates. Link to comment Share on other sites More sharing options...
Dark&Stormy Posted October 14, 2016 Author Share Posted October 14, 2016 I learned how to clear the fault code. You have to enter diag mode, cycle through the diag codes until you see 69 in the data slot, and then press the starter switch to on. the "69" will become "0". Link to comment Share on other sites More sharing options...
